list of parts to buy, have a look over please.
laichi
8
Decided on part for putting together a designing machine, one I can upgrade around later.
From UK,London
Something i've always wanted to do is build a PC from scratch.
Main use will be cs6, wed development , making music for now.
Could you take a look and let me know if Thier's anything i'm missing or if a part is not compatible etc
25" 6x Slot Card Reader with Audio/Mic, 4x USB 2.0, 1x eSATA, 2x USB 3.0
£22.78inc VAT
LN40445
550W Corsair Enthusiast Series Modular, 85% Eff', 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX, PSU
£59.46inc VAT
LN42857
HOT SELLER 2TB Seagate ST2000DM001 Barracuda 7200.14 SATA 3 6GB/s 7200rpm 64MB Cache 8ms OEM NCQ
£62.64inc VAT
LN45587
2GB Asus GT 640, 28nm, 1782MHz GDDR3, GPU 901MHz, Shader clock 1802MHz, 384 Cores, D-Sub/ 2x Dual Link DVI-D/ HDMI
£71.57inc VAT
LN48057
16GB (2x8GB) Corsair DDR3 Vengeance Low Profile Cerulean Blue PC3-12800 (1600), Non-ECC, CAS 10-10-10-27, XMP, 1.5V
£118.99inc VAT
LN52463
Asus H87-PRO, Intel H87, S 115ATA III, SATA RAID, PCIe 3.0 (x16), VGA/DVI/HDMI/DP
£85.04inc VAT
LN52598
HOT SELLER 120GB Samsung 840 EVO SATA III Basic Slim 7mm 3-core MEX Controller Motherboards Write 410MB/s 256MB Cache 94K IOPS
£76.94inc VAT
Dec1Inc
LN52890
HOT SELLER LiteOn DH-4O3S-04-B 4x Blu-ray, 8x DVD Reader SATA OEM - Enjoy High Definition Blu-ray and DVD movies on PC
£23.28inc VAT
Dec1Inc
LN52913
HOT SELLER Intel Core i5 4440, S 1150, Haswell, Quad Core, 3.1GHz, 3.3GHz Turbo, 1100MHz GPU, 31x Ratio, 84W, Retail
£138.18inc VAT
Dec1Inc
Add product LNn
Sub Total (inc VAT)
Delivery Charge
£660.0
£10.98
Checkout
Total (inc VAT)
£670.98
Plus the lzxt phantom case £80
Windows 7 £75
Total £825
For the mother board other choices are
MSI Z87-G41 PC Mate Intel Z87 Socket 1150 Motherboard-£74
Or
MSI H87M-G43 H87 Micro-ATX Motherboard Socket 1150 Haswell-£67
Will have 5.1 sound via HDMI source.
Need the go ahead, would like to get it going asap.
Lastly will the drivers for parts have to be downloaded previous to booting.
Thanks for your time
Best wishes
great build, should last a decade
with the other mobos, you just save 15 - 20 pounds, so you may as well go with your selection of asus
No, not required. most components have driver and utilities cds in the box itself. if you have internet, you will benefit as they will check and install the latest drivers.
your gpu, is that finalized? what options you got in that price range. this should help with your selection
point made. nice one. managed to get a faulty laptop up and running recently with os 7, 4gb ram. might end up using this for a few months picking up parts for the main pc over the course, clearly no need for it now.
Well it comes down to an extra 20 for a 2gb GPU in the end so went for it. Feels like an expensive build and not a budget one. Could probably get away using cheaper parts so might re consider, as will hardly be for used for games. Main concern was compatibility etc. Thanks for clearing out.
m x mas-, best wishes to the new year.
