Few questions i’m hoping someone can answer and help me solve my current issues. Pics below.
First let me say this is because my thermals were way higher than normal for a new PC.
I was pushing 100+C playing games at 1080p on low and medium settings at stock. No OC on this PC has been done. Air movement is good and the CPU doesn’t even break a sweat.
I decided to check into thermal paste/pads and see if this corrected the problem. Reading some other posts and watching videos it seemed like it would be a probable solution.
Now comes the part where either I went full tard, or something is wrong here. I unmounted the GPU and disassemble.
First thing I notice is what looks and feels like plastic on the plate. I peel back just a tiny little section on a corner and sure enough it feels like plastic that’s been cooked brittle due to heat.
Also, its adhered to the metal plate which from my understanding thermal padding doesn’t have. There is glue residue on the entire plate. This looks like the plastic it would’ve been covered in when in stock to keep from scratching. Please advise if i’m wrong here.
Now the next issue. From all the videos and tutorials I read showing how and where to apply thermal paste or pads, none of the other 6900xt have looked like this. Any advice here would be welcomed!
https://share.icloud.com/photos/047nIbQf1ixLf52eHXu-kkmlA
