Little problem on max Rex
auchi
14
Hi guys
Im the happy owner of a new t220hd, not the greatest gadget on market but pretty sweet for its purpose, although I came across a little annoying problem, cant set my desktop to 1680*1050, which is supposed to be the max resolution
I have a hd2600XT on my specs, maximum res of 2000*xpto so i guess it isnt the graphic card
I also have another monitor plugged in, but i tried disabling it (both physically and only with ATi CCC) and didnt help
T220hd is plugged by a dvi cable, both graphic card and the LCD/TV accept dvi-d. Im using a cable that came along with the LCD/TV, I cant tell if its digital,analog or even if that would make a difference
Any hints on this would be appreciated ^^
ei again,just answering myself in case some1 gets same problem
All i had to do was switch dvi connectors on my graphic card, for some reason windows mess it up and doesnt allow the 2nd dvi to output anything higher than 1600.
Cheers
