Hi to all,
I have a mind puzzle. I want to broadcast live stream video from my Canon 70D using my latptop.
I have read around that a hdmi-sdi converter is required. Now, I have found this converter: http://www.amazon.com/Excelvan-MINI-HDMI-Converter-Theater/dp/B00ID4BVD0/ref=pd_sim_sbs_23_4?ie=UTF8&dpID=41CZJSl%2BwEL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=06ZHNQDZ4K0GKKDY0V5R
It is much cheaper than black magic mini-converters. The big problem is that it does not have a usb port to plug it into my laptop. So I cannot really use it, unless you can link me to online stores selling "sdi to usb" cables. So, I have thought about the following alternative ways:
1) This hdmi-sdi converter has a mini-usb power port: http://www.amazon.it/dp/B00DHKCZ26/ref=asc_df_B00DHKCZ2630646726?smid=A11IL2PNWYJU7H&tag=kelkooit-ce-21&linkCode=df0&creative=23422&creativeASIN=B00DHKCZ26&ascsubtag=dc1-kls-prod-srv-02.prod.dc1.kelkoo.net_1450015811140_1789471
I am wandering if I could use the usb port to convey the sdi signal to my laptop.
2) I have found this hdmi-vga converter that I could use it to connect my camera directly to my laptop: http://www.amazon.it/dp/B017VYYQ34/ref=asc_df_B017VYYQ3430545034?smid=AQYHPY0BKWKJN&tag=kelkooit-ce-mp-21&linkCode=df0&creative=23426&creativeASIN=B017VYYQ34&ascsubtag=dc1-kls-prod-srv-02.prod.dc1.kelkoo.net_1450016384160_1792498
I am wandering if a hdmi-vga conversion would do as much as a hdmi-sdi conversion.
I would be grateful if anyone could kindly tell me if any of the two alternatives I mentioned above would make the live stream work or help me to find other inexpensive solutions.
Cheers
Stefano
Cheers
Stefano
