Question Livekernalevent 141 - Monitor goes black, fans and lights still on, audio still playing
Danielzheng0291
6
Hello all,
Recently, I have been experience this bizarre issue where the monitor suddenly loses signal but the PC remains on. All of the fans are spinning and whatever application I am running is also function. If I was watching a youtube video, the audio will continue to output through the headphones and I can even rewind using the arrow keys just that there is no display. This issue would happen as much as 6 times a day or none at all. The workload also doesn't seem to affect it since this would happen on a single tab of Chrome or while running EscapeFromTarkov. I have also stress tested the system using AIDA64 Extreme and it ran fine for about 20 minutes with no singles of overheating or thermal throttling.
I have pinpointed the error to be livekernalevent 141. I have scoured the internet for solutions and tried a bunch of them.
- Reseated ram
- Reseated GPU
- Used DDU to uninstall old graphic drivers
- Used chkdsk
- Used sfc /scannow
- Undervolted the GPU and lowered the boost clock
- Tried a different PSU
My Specs are:
- Ryzen 9 7900x
- Asus b650e-f gaming wifi mobo
- Flare x5 32x2 ddr5 6000mhz ram
- Corsair sfxl 1000w
- Asus rtx 3060ti
Here is the reliability history error code:
Source
Windows
Summary
Hardware error
Date
‎1/‎24/‎2024 7:27 PM
Not reported
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffbb051b193010
Parameter 2: fffff8057362f270
Parameter 3: 0
Parameter 4: 0
OS version: 10_0_19045
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.19045.2.0.0.256.48
Locale ID: 1033
Any advice would help. Thank you.
