[SOLVED] LL120 problem
Jun 14, 2020
15
Hi everybody
I had three ll120 in my system before, and I wanted to add three more because then it would look cooler (I have the Lian li PC o11 dynamic, I had one ll120 on the bottom with two other fans and two ll120 on the side . Before I had installed these my three fans would light perfectly as they should and they weren't noisy or spinning very fast. But then I installed my three new fans, the three at the bottom won't light up, not even the old one that worked earlier, and suddenly began to spin really fast and become noisy. I tried to rearrange two of the cables on my lighting node pro but it still doesn't work. I hope you can help me
The lighting node pro has no connection to how the fans spin or perform so you're having 2 different problems.
Fan spinning issue first. How are the fans connected to your motherboard? Splitters? Are you using 4 pin splitters? Are any fans on splitters also connected to a c pin fan of any sort? After installing the fans did you run your motherboard's software fan calibration?
Regarding the lighting node pro. You need to go into iCue and specify that you now have 6 fans connected, click on the lighting node and then Channel 1 (assuming thats what channel you are on) and then check the drop down and make sure its set to 6.
Three of my fans are on splitters and three are connected to my motherboard. I just ran the fan configuration, and now all of them are quite thank you very much. And it also worked setting it to 6 on channel 1. Before It were two channels and I put three on each. Thank you very much for the help I really appreciate it 😄
No Problem! I actually just went through setting up a new lighting node pro in my new case adding more fans and so on, so I literally had the same problem as you did, yesterday.
Reactions: Jennerthebenner
