[SOLVED] Lm under ihs and liquid cooler still 98c
Dec 27, 2018
8
I applied liquid metal under my overclocked x3440 Xeon IHS, and with a hyper 212 evo acheived 50c under full load, (I'm using thermal grizzly kryonaut as well for paste) which is extremely impressive in my opinion. I got a liquid cooler for it and now temperatures are in the tj Max, what did I do wrong? It's extremely frustrating and I don't know what the issue could be
I made sure to take the sticker off, and I used a fresh thermal grizzly kryonaut application. I can here liquid flowing through the tubes, so I imagine it is working fine .... But that's why I came here cause it ain't working
If it works with previous cooler then its probably 1 of 2 things.
Either the pump is not functioning, which you said you can hear/feel the liquid circulating.
Or it is not making proper contact with the cpu ihs.
Hahaha the caps on my board prevented it from being mounted the way I wanted to. I get 16c better temps now, 34c under full load
Thanks guys
