Load at 800 W ... rating PSU output at 750 W
capital_one
350
then what does "at 100% load means" :??:
cjl
Splendid
Why? It's a no-name brand and has very mediocre reviews.
ronss
191
here is a review on the topower 900
http://www.hardwaresecrets.com/article/738
it gets a good review,,but out all i listed, it would be my last choice..
couple good links for power supply reviews-
http://www.hardwaresecrets.com/page/power
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Review_Cat&recatnum=13
these 2 sites do excellent jobs on reviewing power supplys
this coolermaster is suppose to be good-
http://www.ewiz.com/detail.php?nam [...] a6b497148c
xfx is also rated great
http://www.newegg.com/Product/Prod [...] _-17207001
this is the one i probably would buy-
http://www.mwave.com/mwave/SKUSear [...] ia=BA50048
here is a 900w with good reviews-
http://www.newegg.com/Product/Prod [...] _-17342012
another good corsair,,,-
http://www.newegg.com/Product/Prod [...] 6817139013
any of the above would be great psu,,with the corsair hx850 having 7 year warranty, and excellent intermal components
Message quoted 1 times
Message edited by ronss on 03-03-2010 at 03:51:51 AM
Revove from the list of quoted messages Add to the list of quoted messages Quick edit Edit this message
cjl
Splendid
I agree that a Corsair HX850 would be a better choice (though the one you linked to as a "900W with good reviews" quite simply doesn't have good reviews). If the OP already has the topower though, it should work just fine.
Nowa
44
That power supply calculator on ASUS's site is utter rubbish. For example increasing your fans by 3 or adding a HDD increases the required wattage by 50. No HDD or fan uses even close to that much power. You should try a proper power supply calculator like this http://extreme.outervision.com/psucalculator.jsp before you go buy a new power supply for yourself.
jsc
Champion
:lol: :lol: :lol: :lol:
A single 9600GT needs about 5 amps (60 watts).
[strike]The Asus power supply calculator must be a piece of crappy software.[/strike]
Never mind. If you can't say something nice about someone, don't say anything at all.
capital_one
350
just select one 9600 nvidia and see the power rating :)
capital_one
350
"this PSU calculator" .....which PSU calculator were you working ON :sarcastic: :lol:
capital_one
350
everything will change with a lighting thunder the moment i switch from 9600gt to GTX 260 or GTX 275 or even a 9800 gt
:lol:
shubham1401
2,754
88
You Have two eyes?
Just read the post above the one you replied...
BTW I clarified that in the post in which I wrote:
'I too, got the result from Antec PSU calculator :) '
We're Just trying to help you...
cjl
Splendid
Honestly, 350-400W is MUCH more believable for that system than 800+W. I would say that the calculator you used in the OP was complete garbage.
capital_one
350
ya but just one head :lol:
capital_one
350
so why would a 20 billion US$ company like ASUS create garbage
purposefully :sarcastic:
cjl
Splendid
I don't know. I do know that I've measured my system's power consumption at right around 800W though, and it uses a pair of 4870x2s, 5 hard drives, and an overclocked i7 that runs only slightly cooler than a nuclear furnace (well, OK, my TRUE does a darn good job, but the amount of heat my computer can pump out is staggering. I haven't turned on the heat in my room in a month, despite it being cold with the window slightly open for ventilation). If 3 9600 GTs and whatever else you have in your system comes to 800W, I'd be shocked, because I'm fairly certain that on a 1 to 1 basis, a 9600 GT GPU uses less power than a 4870.
Besides, I just put my system into that calculator, and it recommended a 1200W minimum. I've been running it for almost a year and a half on a Corsair HX1000, and I've actually measured the power consumption at 800W peak. That pretty much confirms that the calculator there is garbage.
capital_one
350
oh really :??:
could you please show me with one exact example how this ASUS page is a bad decision by ASUS
http://brainstormtech.blogs.fortune.cnn.com/2009/11/20/the-man-behind-the-netbook-craze/
Similar threads
