Loading Lag hiccup fix help!!
Joperdeploop
19
Hi i build my System some time ago. I am experiencing what i call loading lag..., it is lag that only happens at Points where it is loading an Area..., when the area is loaded it is buttery smooth. I noticed in gaming with task Manager the read Speed on my ssd did not got above 10mb/s..., what is causing This? I have in every Game good fps only Games i saw Below 60 where arma 3 and DayZ.., changing resolution does not fix the stutter, but turning the settings to low does, but i got almost no fps difference..
Is it becaus my ssd needs to load the textures and stuff??, is it the power supply?
Specs:
-Cpu: fx 8350 4ghz
-Mobo: asrock 970 extreme3 r2.0
-psu: Corsair cx 750
-gpu: R9 290 tri-x
-storage: Samsung evo 850 250gb
-ram: Kingston hyperx beast 2400mhz clocked at 1866mhz
-monitor Asus v248qe 144hz 1 ms
Fps is every Game is yummy but those loading lags are horrible, i also noticed that the cpu was throtling when turbo mode was on, so i left it on stock( 4ghz)
