Archived from groups: microsoft.public.windowsxp.basics (
More info?)
<anonymous@discussions.microsoft.com> wrote in message
news:264a01c4a4ee$33f87870$a501280a@phx.gbl...
>>-----Original Message-----
>>news:3ebc01c4a4e3$fead2cb0$a401280a@phx.gbl...
>>>>"Jan" <cairnes@bellsouth.net> wrote in message
>>>>news:3bda01c4a4c1$7428a280$a401280a@phx.gbl...
>>>>> When my song logs on he enters his password and his
>>>>> desktop comes up and then automatically logs off. Any
>>>>> suggestions?
>>>>Can you log on with other accounts on that computer? If
>>> so, then there's
>>>>something in his profile that's corrupt, or something
>>> that he's got set to
>>>>load at startup that isn't working right.
>>>>Can he start in Safe Mode? If so, he can start disabling
>>> startup items until
>>>>he figures out which one is causing the problem.
> Checking
>>> the event log
>>>>would also be helpful.
>>>>If none of the users can log in, and none can start in
>>> Safe Mode, have you
>>>>tried Last Known Good from the same menu that gives you
>>> safe mode?
>>>>His is the only profile on the computer. He cannot start
>>> in Safe Mode - it does the same thing. He has run the
> Last
>>> Know Good from the same menu and it did not correct the
>>> problem. Thank you for the reply and please pass along
> any
>>> other thoughts you have.
>>Does it start to log on, then go directly to "saving
> settings"?
>>YES, it does go directly to "saving settings"
Okay, you've removed and/or disabled some spyware, but the line that starts
the spyware is still there.
You need to boot into the recovery console with the XP CD. Choose "R" for
repair when it asks.
type this at the C prompt:
copy C:\windows\system32\userinit.exe C:\windows\system32\wsaupdater.exe
then restart the system. You should be able to log on.
Then you need to edit the line in the registry that's looking for the
spyware.
Go to Start, Run, and type regedit.
Go to :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Look for Userinit
it's supposed to read:
C:\WINDOWS\system32\userinit.exe
So whatever else is there, fix it.
then make sure that you run whatever spyware removers and antivirus programs
that you have.
Good luck.
