login problem to a persistent connection to a mapped drive
Dan
2,208
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
We have several Windows XP workstations in a workgroup configuration. They
have a persistent connection to a mapped drive on a domain-member server.
The users are trying to log in to a local account on that server.
Because the workstation password is different than the mapped-drive
password, that local account keeps getting locked out and the users have to
wait 30 minutes, after which time they can access it with no problem.
Barring that they can log in if we unlock the account. What we suspect is
happening is the Windows is attempting to connect to the drive with the local
account used to log onto the XP workstation and retrying a few times after
the password fails.
The following errors appear in the event log.
Event Type: Failure Audit
Event Source: Security
Event Category: Account Logon
Event ID: 681
Date: 4/22/2005
Time: 11:43:55 AM
User: NT AUTHORITY\SYSTEM
Computer: SERVER01
Description:
The logon to account: lsmith
by: MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
from workstation: WRK01
failed. The error code was: 3221225578
Event Category: Logon/Logoff
Event ID: 529
Date: 4/22/2005
Time: 11:43:55 AM
Computer: SERVER01
Description:
Logon Failure:
Reason: Unknown user name or bad password
User Name: lsmith
Domain: WRK01
Logon Type: 3
Logon Process: NtLmSsp
Authentication Package: NTLM
Workstation Name: WRK01
We know the best solution would be to make them all members of a domain and
use domain accounts. Suffice it to say that is not an option. Increasing
the number of failed attempts before the account locks is also not an option.
What we think would be a good workaround is to find a registry fix that
would limit the number of login retries to 1, so the user would get prompted
with a password rather than the system retrying multiple times and locking
the account. Does anyone know how to do this?
Any other ideas would also be appreciated.
Thanks Dan
Dan,
Have you considered using the "Map network drive" feature and specifying
a different username and password - Although this is something I'm currently
experiencing some odd behavior with (reconnection issues) the behavior
should work to solve your issues. Another solution is to use a local
loginscript - a simple batch file in the startup folder of the local user
mapping the drive with domain credentials.
Syntax of: net use [drive letter]: \\[member-servername]\[sharename]
password /user:[domainname]\[domain-username] /persistent:YES
Word of warning here that the password is kept in plain text - <MS guilt
trip> C'mon folks how long has the 'net use' command been around and we
still have to worry about plain text passwords? </MS guilt trip> so it is
inherently insecure - however I've found a couple of neat VBS scripts that
can prompt for username and/ or password that you can simply embed in the
batch files - users enter the password once and the drives are mapped.
(Great for users offsite with expired passwords).
VBS - search for userin.vbs and passin.vbs
Hope this helps,
JF
"Dan" <Dan@discussions.microsoft.com> wrote in message
news:85FD60CF-CE69-4B6D-A2EB-8C604D3270AC@microsoft.com...
They
to
local
> the password fails.
> Event ID: 681
> Date: 4/22/2005
> Time: 11:43:55 AM
> Computer: SERVER01
> Description:
> Event ID: 529
> Date: 4/22/2005
> Time: 11:43:55 AM
> Computer: SERVER01
> Description:
> Logon Failure:
password
> User Name: lsmith
> Domain: WRK01
> Logon Type: 3
and
option.
prompted
> Thanks Dan
Thanks Jim
We tried the different user name but it still locked the account.
Here was our simple fix: Map the drive, create a short cut of the mapped
drive to the desk top, then disconnect the mapped drive. Any subsequent
time that the user logs in all they need to do is click the short cut and
they get a login screen.
W did attempt the login script which worked fine. We preferred the Gui login
box to the script command prompt box that many of our staff would not be
familiar with.
Dan
"James Fabulous" wrote:
> Dan,
> Hope this helps,
> JF
> They
> to
> local
> > the password fails.
> > Event ID: 681
> > Date: 4/22/2005
> > Time: 11:43:55 AM
> > Computer: SERVER01
> > Description:
> > Event ID: 529
> > Date: 4/22/2005
> > Time: 11:43:55 AM
> > Computer: SERVER01
> > Description:
> > Logon Failure:
> password
> > User Name: lsmith
> > Domain: WRK01
> > Logon Type: 3
> and
> option.
> prompted
> > Thanks Dan
