Logisys CS305BK Case 480W Power Supply
davidbsmih12
Commendable
Mar 20, 2016
17
I am currently searching for parts to do a budget gaming PC build and I wanted to know if the Logisys CS305BK Case which comes with a 480W Power Supply is worth it. Also, will the power supply cause unexpected shutdowns and does it have enough connectors to handle a EVGA GTX 950, an HDD and an optical drive?
Thanks, David Smith
Yes it will work...
BUT....
Through experiences with PSU that come with the case, none of them are stable except ones from notable companies, like antec, ROSEWILL, or such. Logysis is not a great company and I would not recommend their PSU.
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
According to this you should toss it immediately and get a good unit. The list also explains a lot about auality differences. Never cheap out on a PSU.
I don't like what I see. The PSU may be 480W. But I'm going to almost guarantee the quality isn't very good. Never overlook your PSU. But to actually answer your question. No it isn't worth it.
Yes it will work...
BUT....
