Logitech ClearChat Pro - sounds fine at work but not at home
redvandam
76
I am having a problem with the USB headset/mic I bought. When I use it on my home computer the sound is whisper quiet and distorted. When I tried them on my work computer, they worked fine. The sound was loud and clear, the mic had decent playback. I tried them again on my home computer and they are still as bad as before.
What could the problem be? Where should I start looking for conflicting software? I've also already tried every USB port I can.
The headset is a Logitech ClearChat Pro - USB.
Try adjusting the settings in your sound manager program - icon may be in the system tray and should also be in the control panel. You should be able to plug-in the headset and mic, then adjust items like noise cancellation, volume, etc.
