W wdadws Reputable Feb 27, 2014 121 0 4,680 Oct 10, 2014 #1 so guys, i just bought the F710 Controller from logitech ... i was happy, but when i open it ,,, no charger .... so, does F710 didn't need to charge ? please answer guys ..
Solution Phillip Corcoran Oct 11, 2014 It uses two non-rechargeable AA batteries inside the controller itself. Fit new ones as needed. See "Specifications" at bottom of this page: http://gaming.logitech.com/en-gb/product/f710-wireless-gamepad I found it in 5 seconds using Google Search, you should try it sometime.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Oct 11, 2014 Solution #2 It uses two non-rechargeable AA batteries inside the controller itself. Fit new ones as needed. See "Specifications" at bottom of this page: http://gaming.logitech.com/en-gb/product/f710-wireless-gamepad I found it in 5 seconds using Google Search, you should try it sometime. Upvote 0 Downvote Solution
