Logitech G430 Low Volume with USB Adapter. PS4 and PC
Bianchi789
83
Hi all.
I just bought a Logitech G430 and I am having some volume issues. I tend to use the headset without the USB adapter while on my PC just because of the volume difference but when I use it on my PS4 I need the mic so I need to use the adapter.
If there anyway I can increase the volume with the USB or use the mic and headset without the adapter on the PS4? Or do I just need to buy an amp?
If the only way to fix it is to buy an amp do you know of one that can work with this headset on my PC and PS4? I would like the max volume to be.....deafening.
Thanks in advance.
The headset has 2 3.5mm cables, one for the mic and one for the sound. Is there anyway I can still directly connect both. If so how? Thanks
I do have one that came with the headset but that's limiting the volume. Do you know one that I can get that won't do that.
Thanks
