Logitech G610 LED noise
opsis28
Commendable
Nov 2, 2016
Hello. Yesterday I bought a G610 Orion Brown keyboard. Keyboard is really nice, except one thing. When backlight is in medium state, keyboard produces buzzing noise. It's not very audible, but when it's quiet in room, a noise is annoying. There is no noise when backlight is in brightest position or is turned off. So I would like to ask is this is normal, or I should return keyboard to my local retailer?
Its a known issue but there is a workaround/fix in the software
in the Logitech keybd software, go to settings, select the general tab, and then graphics properties. Check first box which says "enable advanced graphics". Restart the software and test. You need to change the brightness witht he software from now on IIRC.
If it fails now return the keybd.
