Logitech G633 cable problem
Muraka
It's a braided cable, I bought it around 2 weeks ago, and it started getting tangled this is probably due to the cables being too close together and I fear it might damage my headphones, and does it harm my headphones if so please give me a solution to solve this
with my previous headphones I think it died because of the cable it had the same problem
but I did not give too much attention to it, and my retailer revoked my warranty because of the cable's problem (barley knows anything about tech if it matters),it had this power surge problem where it states that it is pulling too much power than the USB port can support (This was my previous headphones not my current one, 18 Months of use)
and telling me the amps of the USB data cable from Logitech g633's original cable would be very helpful
This is caused by you, the cable twists like that because the headset gets spun - usually while putting it on & off. You don't even notice you are doing it.
Unplug the headphone and let the cord dangle and unspin itself. I know its a long cord so you may need to help it a bit esp in keeping it straight and off of things like the floor.
Once its straightened out again, just let it unwind itself when you see it start twisting again. I'm had my older headphones for 3 yrs without issue now. :)
