Question Logitech G703 Lightspeed mouse not working, and mouse wheel with Logitech logo is blinking on red ?
Sep 18, 2022
Hi,
can somebody help me troubleshoot this problem ? My Logitech G703 lightspeed started blinking on red (mouse wheel and logo) from one day to another and stopped working. When I turn it off and connect the cable only mouse wheel starts blinking on green as it was recharging. I tried to disassembly the mouse and disconnect battery and try to connect mouse without battery but nothing changed -> if mouse is on it's blinking red and not working (with and without battery) and if it's turned off and connected to cable it's behaving as it was charging. It's is not showing in Logitech GHUB and I tried uninstall every mouse driver and tried to connect it to different Pc but without any luck. Also mouse is 2,5 years old.
Thanks for any suggestions
see if this helps
Please follow the below mentioned.
  1. In Windows Settings, open Apps & features.
  2. Search for Logitech G HUB.
  3. Click on Logitech G HUB and click Modify.
  4. In the new window, select Reinstall G HUB, then click REINSTALL.
  5. G HUB will reinstall, and this will resolve the issue while retaining the settings.
link
G Hub is the cause of a lot of battery problems, just not that mouse.
Reactions: dudio
