Logitech G920 Problems
ginningfool97
232
I recently just purchased a Logitech G920 racing wheel for my PC and XBONE, and the experience isn't what i thought it to be. For starters it would fit on my desk because it was too thick , by a few mm. So i used it for my Xbone and the tv and box are on a stand so i used a TV dinner table to put it and the shifter on but the table is very easy to move so i guess thats why the experience isn't good. Second it can't be used to drift on FH3 or FM6, I don't know why but the wheel has a mind of its own if i turn itover half way to the right or left it decides the car's tires will go as far as they turn in that direction even tho i haven't turned that far. I can drift fine with a controller but not on that thing if i hit the hand brake the wheel does what it wants i turn down FFB and vibration and still hit the handbrake and car does not recieve any of my imputs, wheels turn but it just has a mind of its own. Peice of junk for $350. all that down the drain and can't return it because i took it apart and took the rubber peice out of the brake. just gr8 🙁
Just now i plugged it in to play some FM6 to see if i could straighten out the settings and not it won't recognize the wheel at all
You need to change rotation settings. You might want to look up what settings others are using. It could be possible that you were lucky and got a faulty one but now you can't return it. Don't ever do anything to void the warranty on any product you buy unless you know it is working properly.
Worked completly fine for the past 2 days that's why i decided to do it.
