Logitech G933 Default Audio Device
jalonsolabori
18
Hi..!!
I just bought a Logitech G933 for my son's computer, but when the battery runs out I have to go to control panel and change the default audio device from G933 to my PC speakers.
Is there a way for Windows do it automatically,
We have Windows 10
Thanks in advance,
Hi:
I found this solution in another thread and worked like a dream.
"Assuming windows. Go into sound, make sure both the wireless headset and speakers are enabled. Change to the "recording tab" and you should see a device called "stereo Mix". Go into the properties and change to the "listen" tab. Check the box "listen to this device" and then under "Playback through this device" select the G933 device from the list. Windows will now mix the playback (even though its under "recording"). If the G933 is not in the list, then it is probably disabled and you need to right click and enable it in the playback tb."
Hi:
