Logitech G933 Or Corsair Void Pro RGB Wireless
I would go with the Logitech G933. I've had both headsets and had a pretty bad experience with the Corsair Void Pro Wireless RGB. My charger port started to give out on it and also the software for the void was terrible. The Logitech G933 is just a more prime headset, and has a better battery life. If you can afford it then I'd definitely go for it! Good luck happy picking!
