Tried the Logitech forums, but, no luck... tried finding tech support info that wasn't a phone number with no luck either so, hoping someone here may be able to shed some light.
I bought a Logitech K800 this week, though had no real interest in the wireless aspect. I liked the look, size, feel etc so, planned to plug in the USB and simply leave it plugged in 24/7.
Problem is, the feature of having the lights turn off automatically isn't working. Unplugged everything works fine, plugged in the lights never turn off. If I switch the keyboard off/on they turn off but only come on again if I press a key, then remain on as long as the computer is on. The dimming works fine... if I cover up or shine a light at the sensor the lights dim/brighten. They just don't shut off.
I downloaded their setpoint software, made no difference, except if I choose to disable the lights, then they go off and stay off. Off-chance was a driver issue, I uninstalled setpoint, went into device manager and deleted everything, rebooted and let everything re-install but no changes.
Most I got from the Logitech forum was that 'it should work' which wasn't helpful, and no idea if the person knew for a fact it should or just guessing.
So... does anyone have a K800? if so, when plugged into USB does the hand detection work and do the lights auto shut off?
