[SOLVED] Logitech M100 randomly gets disconnected, need help fixing it!
Dec 27, 2020
4
my pc specs are:
ASRock b450m pro4
16Gb ram 2x8 3200Mhz
ryzen 5 2600
gtx 1660 Super
500W System power 9, BeQuiet!
kingston 500Gb SSD.
Yeah on older systems it works just fine!
Check for a BIOS update and chipset driver for the motherboard. Try a few other USB ports also. If you are using any extender cables or USB hub with the mouse plug it in directly to the system instead. Is this the only thing that is wrong with the system? Have you tried another mouse with it?
