Sorry I thought you wanted a solution to a missing receiver.
In order for the transmitter in the mouse to communicate with its receiver, they must be paired. This means that both devices are operating at the same frequency on the same channel using a common identification code. A channel is simply a specific frequency and code. The purpose of pairing is to filter out interference from other sources and RF devices.
Pairing methods vary, depending on the mouse manufacturer. Some devices come pre-paired. Others use methods such as a pairing sequence that occurs automatically, when you push specific buttons, or when you turn a dial on the receiver and/or mouse.
To protect the information your mouse transmits to the receiver, most wireless...
