Hi guys,
Just a quick question regarding the Logitech Pro X headset 3.5mm aux cable. I've been having issues with my headset. As an example, in discord, my friend can hear me, but his voice doesn't come through my headset. I've played around with the voice setting etc but nothing works. I had to put his voice output on my speakers.
I moved the 3.5mm cable around which eventually I was able to hear myself with mic check in both discord and in G Hub.
I'm looking at grabbing another cable as a troubleshooting method. Am I able to buy any 4 pin trrs cable to try? Or am I better off trying to source a logi 4 pin cable? I'd rather try this than buy a new headset if the fault is internal.
Thanks guys.
Thanks guys.
