Logitech USB mouse double clicking after single click
enderkevin13
22
Why is it doing this exactly? I really wanna fix this as soon as I can. It's bothering me so much when playing Classic Doom because when I'm using the chaingun, it stops firing while I'm holding down the mouse button.
Get a different mouse.
I was on my 3rd Performance MX mouse due to the same double clicking problem occurring after a few months of use. Long story short I brought a M705 Marathon Mouse and never looked back its on its 4th year and its still using the same batteries it came with! $19 at BJ's as opposed to the $99 I spent on the Performance Mouse at Newegg.
Trust me, I went through the rubber chicken solution they cave on their forums on taking out the battery, pressing all the buttons, even as to take the mouse apart, take apart the micro switch and clean it with WD40 and it still does the same thing.
it sounds like a switch inside the mouse is failing. I have had a couple mice do the same exact thing.
unless you are good at micro soldering, I suggest a new mouse.
if the mouse has 4 buttons + you could re-map the functions and use other buttons
The left click microswitch is failing. It happens.
Fix? New mouse, or completely disassemble and replace the microswitch.
