Logitech z906 Front right speaker not working (with video)
Tacticall993
574
These speakers used to work fine! Now the fright right doesn't work! I'll add a video to show you whats going on. The speaker only works when I attach the red end to the center and the black wire end to the front right speaker in the subwoofer.
[video="https://m.youtube.com/watch?v=CvhabG3HJ1s&feature=youtu.be"][/video]
Unless the amplifier in those speakers are bridged, all of the black connectors are most likely common. This means sticking the red into the center is just sending the center channel signal to the speaker.
I do not see how you are connected.
Try to connect an analog audio(PC/Phone/ect) source to the green(input 1) or the stereo (input 2) port on the back(then select ) and see if it works.
Whenever I have lost a speaker, it has been a cable issue(not saying an amp can not fail).
