long beep sound
kamal jaswal
15
hello gentle men's i have problem with beep sounds
my problem ; i have notice my pc freeze from some
:/ days after re install my os i have run every windows diagnosis i can run on window 7 last night its working good but at morning it start beeping first it boot the bios with one good healthy beep then after the bios window gone its long beep (interrupted beep not smooth) i have try my memory test and it pass try changing my ram module clean it with rubber take out my GPU and cpu un plug and
plug my cpu and case fan remove cosmos battery but noting work
my rig
and fx4300 antech cpu cooler
6gb ram 4*2
gtx 750 ti
450 corsair psu
mob asus m5a782-mlxv2
.....thanks in advance
I suggest reading into the BIOS beep codes: "if you hear an alternating siren-type noise at any time during your computer use, at boot or afterwards, you are dealing with either a voltage level issue or a processor fan that's running too low.
This is a clear indication that you should turn off your computer and inspect both the CPU fan and, if possible, the CPU voltage settings in BIOS/UEFI. "
https://www.lifewire.com/amibios-beep-codes-2624543
i appreciate for your time that means i have to increase the cpu fan speed above the threshold value my current lower speed is 200rpm can i put it auto or increase it by hit and trial as its summers now but my case is always open and i constantly monitor the temp of
my cpu and gpu temp okay thanks i will give a try
i try it and every setting on it also change my cpu cooler to original one but still same long beep
The other option is the voltage level issue. Is your cpu voltage also on auto/default?
