I am going to buy an antenna, Alfa wireless adapter and all the other stuff to go with it. I was wondering if I could plug the Alfa straight into a usb hotspot?
Alfa AWUSO36H 1000mW USB Adapter
I have a flat out the back of my parent and I cant reach the wifi so i went looking and saw all about it. Ive seen they hook an antenna up to the Alfa then to a computer through usb. So i though i could plug the usb into a hotspot. would that work? and ive also seen them getting wireless repeater and doing the same, would that cut out the Alfa?
its fair far maybe 300 meters. Ive seen like antennas that can go for km's.
only a few trees..
so would it be better to get a repeater or stick with what ive got?
Gee - 300m! Usually routers and wifi only work over about 50m. That distance I'd have thought you'd need both a good antenna wifi card and a good transmitting router.
ive seen them doing it from house to their local jobs a few km away...
I have been looking at a 24dbi antenna that would be plenty i know that much but i dont know what to connect it to..
