Hi Guys,
Backstory:
2 of my friends live on a Caravan site. One has recently moved plots from the front near a main road, to the rear which has a river plot etc. Now, the downside to the beautiful view is there is NO WIFI.
The second of the two living onsite, still remains at the front of the site connected to a Sky hub through a Netgear WIFI extender i provided/installed as a new access point giving his own SSID etc.
Idea:
I want to use directional antenna's attached to a 1ft pole on each of there roofs to give WIFI out the back in the second caravan...There is a line of sight, and the overall distance is approximately 300m (probably alot less my guesstimates are way bad).
From what i understand, i need to purchase 2x HUBS with Omni antenna's to which i can unscrew one on each and screw in a directional omni antenna attached to the roof. These will point at each other to create the link.
I'm looking at the following antenna's as a first setup to test if this would work, if it does i'll invest in some better antenna's.
http://www.ebay.co.uk/itm/20dBi-Yagi-Antenna-SMA-Male-Long-Range-High-Gain-Booster-Directional-WiFi-4G-/400999054671?_trksid=p2141725.m3641.l6368
The other option is two of these?
http://www.ebay.co.uk/itm/2-4Ghz-14dbi-Antenna-Panel-WiFi-Wlan-Long-Range-Extender-Directional-Router-SMA-/301109590854?hash=item461b87bb46:g:~XYAAOSwn51UYyen
and a router.. now can i buy ANY WIFI hub with Omni antenna's? Simply unscrew and screw in my external ones? Or is there more to it?
https://www.amazon.co.uk/TP-LINK-TL-WR841N-300Mbps-Wireless-Router/dp/B001FWYGJS/ref=sr_1_1?s=computers&ie=UTF8&qid=1461153587&sr=1-1&keywords=TP-LINK+TL-WR841N+300Mbps+Wireless+N+Cable+Router%22+WIFI+router
Other than fitting the antennas and making the router act as a repeater what else would be involved? Anything i should know about?
Below is a map outlining the rough area were spanning..
Any advice appreciated.
Backstory:
Idea:
