I am working out on a farm this summer and the housing out here just set up Wifi and is using a Ubiquiti Bullet M2HP device as a means of reaching the rooms. The only problem is that the signal is very weak once you are in the rooms which are about 200-300 ft away from the antenna.
I was wondering if there is a solution for this such as buying a range extender or other device to help pick up the signal. Obviously network troubleshooting is not a strong spot for me so I thought I would ask and see if there's an optimal way of fixing this before I spend money and have it not solve anything. Any help is appreciated.
