I am looking to run a long USB cable (about 20ft) from my computer to an area I have set up to run Twitch streams from. Ideally I want to have an audio interface, webcam, and Elgato Stream Deck connected to this USB cable through a HUB. Obviously my biggest concern is power as all of these devices will be drawing power from the HUB. Because of the length (and lack of USB ports on the host machine) I don't really want to run multiple cables, so I am looking for single-cable solutions.
It can be either USB2 or USB3. I have an opportunity along the run to boost the power over the cable through a wall outlet (if I got some sort of powered repeater), but don't know if that will help or be enough. I could run a separate power cable to the HUB, but this isn't an ideal solution as I want to limit the number of cable I have running under/around/behind furniture etc... but it is an option.
I'm also open to non-USB solutions, if any exist.
Here are the devices I am looking to plug in:
Audio Interface:
https://www.amazon.com/Behringer-UMC202HD-BEHRINGER-U-PHORIA/dp/B00QHURUBE?pd_rd_wg=hiSWe&pd_rd_r=f48e05e6-8ee4-4892-a756-178c92eebaed&pd_rd_w=TsKRX&ref_=pd_gw_cartx&pf_rd_r=XDTV1EG62R9F4X92H3RM&pf_rd_p=6b27b606-ba71-500d-b5f8-3510f86504b4
Camera:
https://www.amazon.com/Logitech-Widescreen-Calling-Recording-Desktop/dp/B006JH8T3S/ref=sr_1_2?s=pc&ie=UTF8&qid=1527002876&sr=1-2&keywords=logitech+c920+hd+pro+webcam
Stream Deck:
https://www.amazon.com/Elgato-Stream-Deck-Controller-customizable/dp/B06XKNZT1P/ref=sr_1_3?s=electronics&ie=UTF8&qid=1527002909&sr=1-3&keywords=stream+deck
They are all USB2, so any one of them alone will run fine, but together they exceed the power output of the USB cable (I have tried running the interface and the stream deck together already and it's a no-go even on a short cable run).
Any advice would be appreciate!
Audio Interface:
Camera:
Stream Deck:
