Hey There,
I'm having my home renovated and we had speaker wire run through the walls from where we plan to mount some speakers on the wall to where the subwoofer will be that feeds them.
The system I have is a soundbar system, with 3 channels on the soundbar, which accepts the audio input -- then the subwoofer connects wirelessly and sits at the rear of the room -- it has it's own RCA outputs to feed the rear surround speakers.
From my understanding since I'm only connecting up the system as designed rather trying to mix speaker level and line level, it should be safe.
I need to get RCA ends onto the speaker wire thats dangling out of the wall and I'm wondering if anyone can recommend any good products that are fairly easy to connect in that way? I'm not experienced with soldering and don't own a soldering iron, so anything that uses a screw/clamp method, similar to a speaker post is preferred.
Anyone dealt with this kind of thing before and have any good product recommendations?
Is this what I'm looking for?
http://www.ebay.com/itm/2-Pcs-Speaker-Wire-cable-to-Audio-Male-RCA-Connector-Adapter-Jack-Plug-Bose-/181332508872?pt=US_Audio_Cable_Plugs_Jacks&hash=item2a384280c8
