Hi all,
I'm looking for a 24" or larger widescreen LCD which I will use mainly for gaming, coding, web browsing and some movie watching on my PC and I also would like to use the display for my Xbox 360 preferably in 1080p (although I hear 1080i apparently is pretty damn similar quality the majority of the time).
My first choice was the Dell 2407WFP-HC which seemed perfect until I found out about the inverse ghosting which from all accounts sounds like it would annoy the hell out of me so I canceled my order.
I then (and this is still my choice at the moment) changed the previous order to the 27" 2707WFP Dell monitor. It costs a bit more but I am willing to pay extra if its going to suit my needs well. The one negative thing I have heard about this monitor is that it does not display a 1080i signal in 1:1 aspect ratio properly (in VGA or Component). Apparently it compresses the image and adds black bars down the sides as well as above and below. This of course would only affect my Xbox 360 usage but I would still like to know the extent of this problem and if other users find it annoying enough to suggest not purchasing the monitor.
I am planing on using DVI for the PC and VGA or Component (which ever works/looks better) for the 360. I am not worried too much about the large pixel pitch of the 27" either since I use a 19" monitor which has only slightly smaller pitch at the moment and I have no problem with it.
If anyone can confirm the 2707WFP is a good choice for my needs or if not recommend a better alternative that would be great (I live in New Zealand though so my choices are slightly limited, no LGs for instance). If you don't think the 27" would suit could you please say in which ways it would not be a good choice.
I do have full access to all the Samsung monitors and have heard good things about all of the 245bw, the 244t and the 275t so if any of these would serve my needs better please explain why.
Thanks a lot to anyone who answers, I have been trying to decide on this for ages so if I could come to a decision that would be great.
