Looking for a ATX case for a gaming build
Paynegiver
26
Hello all I am looking for a nice case with good wire management for a gaming pc that I plan on building soon. I am looking for something that will be a solid build quality and adequate air flow.
I like the corsair 500r, however the price of this case has gone up recently and I cannot find it for a price close to what I saw it for ($80).
Main requirements good cable management, good look, solid build, under $100. Side window would be a nice feature but not absolutely necessary
Thank you all in advance
I'd recommend the NZXT Phantom 410. They generally cost $90-$100. They're large for ATX cases and would support just about anything.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146093&cm_re=nzxt_phantom_410-_-11-146-093-_-Product
-Many HDD racks.
-Support for long video cards, and insanely long video card if you remove a modular rack of HDDs.
-Many fan spaces, including on the bottom of the case and a tiltable fan rack positioned behind the HDDs. I think it supports 8 140mm fans, roughly.
-Both sides of the case can be removed.
-Room for cable management behind the backplate.
-Metal sides, unfortunately a plastic front and top.
-3 optical disk drive slots.
-fan control switch on the case.
-smallish side window.
Edit: Heh...
-Many HDD racks.
Edit: Heh. I just saw this one as well.
http://www.newegg.com/Product/Product.aspx?gclid=CNi9iPHNw74CFXQiMgodhCsAQQ&Item=N82E16811146181&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Computer+Cases-_-N82E16811146181&ef_id=UyvDXQAAAL@oizDk:20140524032319:s
Those two look promising, picking a case is proving to be harder than the rest of the build hah
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139009
$139.99 - $40 newegg discount - $20 MIR - $20 promotional gift card w/ purchase, ends 5/26 = $59.99
I did see this one they had the white one for the same price yesterday. I might just end up going with the black one that you linked. Have you had any experience with this case?
