Looking for a basic CPU cooler that will fit my ram
bioshredder
17
Hello people quick question.
I have an Asus P8B75-M Motherboard, I have all 4 ram slots filled with G.Skill Sniper ram, it stands 42mm tall with the heatsink. Now with the intel stock cooler on my i7 3770 fits the ram just fine.
I was wondering if this CPU Cooler would fit with the 4 ram slots (Arctic Cooling Alpine 11 pro Rev. 2)
http://www.pccasegear.com/index.php?main_page=product_info&products_id=14368 - Link to the CPU cooler.
So yeah all I am wondering if this would fit the ram. I have had a look at the measurements, but I am still not 100% sure, or if there is any other cpu cooler out there that would fit (budget is $60 AUD)
It depends on your memory modules, the TX3 EVO clears the RAM in my system. I use G.SKILL Sniper Series 8GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460&cm_re=G.SKILL_Sniper_Series-_-20-231-460-_-Product and I can insert or remove the module closest to the cooler without issues.
That cooler should fit, granted it really doesn't look like it'd make a big difference from the stock cooler. Perhaps I'm just giving the old school style too little credit.
I say it should fit because it doesn't really extend from the CPU socket much at all. The RAM should have plenty of clearance.
I presume you need a new cooler because the stock cooler is defective because the Arctic Cooling Alpine 11 Pro Rev. 2 is not better than the stock cooler. If you need a small cooler that's better, then you should check the Coolermaster Hyper TX3.
Its mainly more for the reason that having 4 sticks of high profile ram, (42mm tall) Most cpu coolers dont have the clearance
Considering my ram is very close to the CPU, I dont think the Hyper TX3 will fit, or is there anyway to work around it not hitting the ram?
