Hi, I've recently got my athlon 64 x2 5200+ stable at 3324.9mhz, but I feel like I can push it a little further with better airflow.
Current heatsink:
Cooler Master GeminII S524 Version 2 CPU Air Cooler with 5 Direct Contact Heat Pipes (RR-G5V2-20PK-R1) https://www.amazon.com/dp/B00UOIK3FU/ref=cm_sw_r_cp_apa_5W4IybD1KRDPB
Came with the silencio fp120 pwm, but can accept a 120 or 140mm fan. I'm really not too concerned about the noise(as long as I'm not breaking into 60dba), I understand that comes with the territory of more air.
I also plan on switching the cpu out for a 95w phenomii x4 955 in the future, and I figure better airflow now, will help when that happens.
Edit: I was considering these
Thermaltake CL-F048-PL14RE-A RIING 140mm Red LED High Static Pressure LED Radiator Fan With Ultra Low Noise (Pack of 2) https://www.amazon.com/dp/B01BYB320S/ref=cm_sw_r_cp_apa_814IybAVMA6RC
Current heatsink:
