Looking for a case to fit Dark Rock Pro3
NickInternational
28
I need to find an case atx with room for the be silent Dark Rock Pro 3 and decent cable management space for under $50, any suggestions? A case with a window would be a plus
Just check the case's CPU clearance, any 180mm clearance will do, if you haven't own dark rock pro 3, some motherboard will not fit if any graphic card populate nearest slot to CPU socket, that's why some motherboard has one PCIeX1 slot near CPU socket so that large cooler such as dark rock pro 3 and nh d15 can fit.
