Looking for a compact ATX PSU for a small case
Calaphos
15
I'm looking for a new PSU in the ATX form factor for my relatively small case - a Rajintek Styx. It has to be shorter than 160mm in length, otherwise it will collide with the GPU.
Because the case is already quite cramped with 2 HDDs and a big cooler I am looking for a fully modular (or at least partly modular) solution with preferably short cables. Flat cables would also be a big plus and are certainly prefered over the thick, stiff cables I have now.
As for power and efficency I am not sure.
So far the Systems consists of a overclocked i7 2600k, a gtx 1060 and several HDDs / SSDs / Fans.
Upgrade plans for the future are a vega or 1080ti style card, so power consumption here will increase. I'm not looking into a dual GPU system however.
Otherwise there is probably a Zen upgrade coming, but that shouldnt change the power consumption.
For Efficiency: I want a decently quit system, especially when in idle. When gaming low noise would be nice, but a GPU is probably louder than a PSU anyways (although right now I've got a louder GPU cooler)
Budget doesnt really matter, as long as it stays reasonable.
According to the link you provided -
STYX / STYX CLASSIC
STYX, RAIJINTEK’s new aluminum Micro ATX case, has a remarkable elegant appearance design and high compatibility with your PC system. STYX is compatible with regular/ standard ATX Power supply.
Any standard ATX power supply will fit.
A tough problem.
Assuming your requirements are truly as stated:
1. LESS than 160mm
2. ATX format
3. Able to handle a GTX1080ti which will be 600w
4. Modular. Note that a modular psu will have relatively stiff connectors at the psu end. Fixed cables will give you more room.
My best suggestion is a SeaSonic S12G-750 which is 5.51" long or 140mm
https://www.newegg.com/Product/Product.aspx?Item=9SIA4CP2MA3921
A similarly sized 650w unit that is priced better is the SeaSonic S12II Series S12II 620
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
It needs to be less than 160, right now my PSU is exactly that length and is in contact with the edge of the GPU. A longer GPU will collide with the PSUs cables.
So far I've considered the Cooler Master V750
https://www.newegg.com/Product/Product.aspx?Item=N82E16817171099
and the silverstone strider series.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817256155&cm_re=silverstone_strider_650W-_-17-256-155-_-Product
Its also available with gold efficency.
Im buying in germany, so the prices are as follows:
The Cooler master 750W one: 101 Euro - slightly cheaper than the 650W version
and the Silverstones: Gold, 650W - 105 Euro or Platinum 650W - 125 Euro
Are those extra 20 Euro worth it for the higher efficency?
Any experiences, advice, etc. especially with the Cooler master PSU?
