Looking for a complete list of parts
shadyattackk
51
Hey all, i've gone through probably 5 pc's in the last 2 years, i should have done this a while ago, but my intellect in this field is rather limited, i know the basics, but when it comes to picking the parts, im a dunce! money isn't a problem, and putting it together won't be either, all i need is a list of the best products money can buy, thanks in advance if you can help!
I'd like it to be able to run as much as 6 screens, each screen could do the same as the one before it, (ie: one for messenger, one for programs i need for school, one for games, not in this order, but each screen should be able to do this, and if it's not to much trouble, would i be able to find a screen specifically for gaming? if there's one available?)
the price isn't a problem, ordering online isn't either,
as for everything else, i'm pretty on the ball with, just as long as it's very fast, reliable, and can handle alot of programs, games and movies,
if you need specifics i could write a few down, but generally speaking, the price range should be about 6-7 grand, excluding the amount for the monitors, that should cost about 4-5 grand, ( again, money isn't a problem!)
shadyattackk
51
also forgot to mention, im a graphics designer, and don't really have the time to look for parts myself, that's why i posted on here, save myself some time! also running vista at the moment, but not to happy with it, so im open to new OS, and thans in advance to those who help!
MykC
480
Well, 10 years ago you might of had to spend $4000 to get a PC to do what you want, but you don't anymore.
Either a base Phenom II 940BE/ASUS 790FX board/8GB of DDR2 800 or an i7 920/Asus x58 board/6GB DDR3 1066 will do the trick. A Sapphire 4850X2 2GB graphics card is good. Put all this in a CM Cosmos 1000 case, powered by any name brand 700W PSU is great. Thats about $1400. If you want grab a Intel X25-M SSD drive and a 1.5TB Seagate drive, throw in a blu-ray drive and your look at about $2700.
Transmaniacon
CASE - 199.99
COOLER MASTER COSMOS 1000 RC-1000-KSN1-GP Black/ Silver Steel ATX Full Tower Computer Case - Retail
PSU - 139.99
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
MOTHERBOARD - 299.99
ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard - Retail
CPU - 288.99
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
CPU COOLER - 69.99
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail
RAM - 270.00
(2) G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory - Retail
OS/APPS - 369.00
Intel X25-M SSDSA2MH080G1 80GB SATA Internal Solid state disk (SSD) - Retail
STORAGE (RAID1) - 260.00
(2) Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
GPU (4 MONITORS) - 289.99
SAPPHIRE 100270SR Radeon HD 4850 X2 2GB 512-bit (256-bit x 2) GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
GPU (2 MONITORS) - 161.99
SAPPHIRE 100258-1GL Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
OPTICAL - 114.99
LG Black 6X Blu-ray DVD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner Model GGC-H20L - Retail
MONITORS - 1379.94
(6?) SAMSUNG 2253BW Black 22" 2ms(GTG) DVI Widescreen LCD Monitor with HDCP Support 300 cd/m2 DC 8000:1 - Retail
OS - 139.99
Microsoft Windows XP Professional SP2C 64-bit for System Builders - OEM
Total - $3984.90
Total (Minus Monitors) - $2604.91
Only thing I would suggest is sticking with MS Vista Premium 64-bit, and maybe bumping the Intel SSD up to the bigger version, http://www.newegg.com/Product/Product.aspx?Item=N82E16820167015, for some more breathing room. You have to have a 64-bit OS to take advantage of more than 4 gigs of ram, which from what you mentioned will be very necessary. I suggested a good reliable monitor, not sure how big you want, but a 22" monitor is pretty popular. You could also get a nice 24" monitor for gaming, and for that I would recommend getting a Radeon HD4870 1GB so as the handle the higher resolution. If your not into a lot of gaming, then the single 4850 will be plenty.
shadyattackk
51
alright thanks for all your replies! im liking the gear transmania suggested, but ima digg into what the other posts linked to! still open to everything,
also the 22's will do nicely, but could i put in something in the 30's maybe close to the 40's for my main screen?
i need alot of room to see everything clearly, but if i did that, would i have to change some parts to make it compatible, so i dont take away clarity from any of the other monitors?
also, the 6 gig's would do nicely, but could i put in what proximon suggested, and use the 12gig kit instead? or would i have to modify some of the parts again?
thanks for your input!
MykC
480
Just out of curosity, why would one need a 6 monitor setup? We aren't confusing screens with windows right?
shadyattackk
51
yee, i need to make it so i can use multi screens,
for other programs, so i can drag and drop, paste, copy,
it'll be just easier then opening and closing windows, i do alot of graphics and testing games n such,
so i need more monitors to do more work, i'll fill in the details in a few, dinner's done!
shadyattackk
51
i need to have at least 4 monitors, i used to use a store bought comp and just changed my vid card so i could use two monitors, but then that blew and im back to one, and it takes double the time to finish my work, so i figure if im two monitors cuts my work in half, then 4 monitors will make it alot easier to finish my work and why stop at 4, i can use the 5th one for regular internet, msn and whatnot, and the 6th for games i need to test, and games i can just play whenever,
also, i wanted to know, if that 1tb harddrive will be in my comp, i can still use my external drive to back everything up right? there wouldnt be any complications?
shadyattackk
51
also, is there a program or hardware i could get to make all the monitors show one picture? i've seen it done with televisions, but never found a way to make my monitors do it, again thanks for all the info!
shadyattackk
51
alright sweet, i'll check into that 40 in, i glanced over it, and i like it so far, but i read at the bottom "Requires a dual-link DVI to run full resolution." is that in the list? or would i need to purchase another vid card or something?
Transmaniacon
No the components selected will allow for good overclocking, and that cpu cooler and the good airflow from the case will keep it all cool. What you could do, its more expensive, but really cool (haha), is run a 30" on each of the GTX285s, and then the 4 22" on the quaddro. It would be an epic set-up, but a little unnecessary.
shadyattackk
51
that's good, but i'll need to be shown how to do that, i've never oc'd before, i've heard and seen it done with other's computers, but haven't done it myself.
ahhahaha that would be badass, i will do that, it'll make my job alot easier, would i be able to make the monitors show one picture? rather then use the 30 in, just combine them all to show one?
shadyattackk
51
Alright, so here's what i have so far, with the help of transmaniacon and proximon, and some info from mykC
CASE - 199.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138
what's the difference between the two?
PSU - 139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
the 1200w psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703020
would there be a problem using the 1200w instead of the 850?
the difference between these two?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131346
rampage II
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131352
again would there be a prob using the rampage instead?
4850's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102809
the duals 285's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130442
trans, you mentioned later that i should go with the dual 285's, that mean i dont have to get the sapphire's?
and then one of these??
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102802
OPTICAL - 114.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136133
MONITORS - 919.99 22"
(x4) http://www.newegg.com/Product/Product.aspx?Item=N82E16824001268
MONITORS - 2400.xx 30"
(x2) http://www.newegg.com/Product/Product.aspx?Item=N82E16824001098
OS - 139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116378
OS/APPS - 369.00
the 80gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167005
the 160gb
trans, you said if i wanted more breathing room i should go with the 160g, which i think i will do instead
trans, you also mentioned something about a radeon HD4870 1gb, that's this right? http://www.newegg.com/Product/Product.aspx?Item=N82E16814161265
i will be doing alot of gaming, maybe 65% of my time i'll be gaming,
KEYBOARD - 79.99
http://stores.tomshardware.com/search_getprod.php/masterid=46646203/search=keyboard/ (if anyone has a better keyboard in mind, feel free to say something!)
was also looking into one of those flexible keyboards, those might be nifty.
MOUSE - 87.90
http://www.newegg.ca/Product/Product.aspx?Item=N82E16826104203
or this one
razor mamba - 130.00
http://www.razerzone.com/p-198-razer-mamba-wireless-laser-gaming-mouse.aspx
this is prettty much what i got from that thread, im guessing this is all i need then?
what about a sound card?
any ideas on speakers or a sound system?
and how would i go about over clocking all this?
It's hard to say how much PSU you need right now because we're still trying to settle this GPU question.
That's the really tricky part of this build. If you fill up all your slots with GPUs you won't have room for any other cards you might want to add in later, like a sound card or TV tuner.
I think your best bet for GPUs:
Sapphire 4850X2
This has 4 DVI ports for 4 monitors. The price is great for this kind of functionality.
EVGA GTX 295
Fastest single card made, for your gaming.
That will leave you some breathing room.
You could power those two cards with the 850W, but for your purposes The PS P&C 1200W would probably be wiser.
fruees
249
Wait, Proximon are you sure he could have a 4850x2 and a gtx295 on the same board???? I know they would be used for powering different monitors and not to combine graphics power, but I still didn't know you can put both on the same mobo and power them
Transmaniacon
Get the 1200 watt PSU so you have room to expand.
The RAMPAGE II is a great overclocking board, if you will be doing this in the future and dont mind spending the extra money to get the board, then get it.
As proximon mentioned, the 4850x2 and the GTX295 will be the best combination. The 30" monitors go to the 295, and the 22" ones on the 4850x2.
As for the SSD, it depends on how many programs/games you will be installing. The 80 should be plenty, but if you are going to fill it up, then get the bigger one.
Technically it's OK, because the drivers are assigned to different devices. However, I see that Nvidia especially gets a bit militant about removing ATI drivers. So, updating drivers would be a huge pain. Apparently it was easier under XP.
So, that leaves you with the second-place 4870X2 and a 4850X2.
How much room do you have? Because you would be better off with two boxes and a KVM switch.... In fact, that would be ideal. You could run some serious graphics on the gaming rig and keep everything else on the secondary, with just a desk switch to move the KB and mouse between the two systems.
Btw, you'll need a good supply of current for all this.
shadyattackk
51
Hmm, so i could get everything that was already stated above,
but get a secondary desktop, that has everything except my graphics stuff? and just link the two with a network switch? im assuming that is a desk switch also?
how good of a supply? something like this? http://www.newegg.com/Product/Product.aspx?Item=N82E16817147073
i have plenty of room, being single, a graphics designer and living in vancouver and being 19, all i have is a bed, tv, laptop and desktop in my living room.. lol (shakes head in dismay)
