Looking for a computer case! Please help!
Anna_27
4
I am looking for a computer case but don't know much about them. The only criteria I currently have are:
- ATX Mid Tower
- Good Cable Management
- Good Air Flow
- Solid Build
- needs to fit a 276mm graphics card (I am having the most issues with this)
I would also like the case to be relatively cheap.
Thanks
http://uk.pcpartpicker.com/parts/compare/bitfenix-case-shinobiwindow%2Ccorsair-case-200r%2Ccorsair-case-cc9011051ww%2Cnzxt-case-cas340wb1/
One of my favorite cases is the NZXT S340. It isn't too big, yet can fit an ATX motherboard with dual card configurations, and already comes with two pre-installed fans that move a decent amount of air and are quiet as well. I'll admit, it isn't ideal for a dual GPU setup (Crossfire particularly 😀.) but it'll get the job done with some decent temps while looking good too. For a single GPU system, even with a higher powered card, it'll be one of the best you can get. If you want a more open style case for better ventilation at the cost of quietness, then take a look at the Corsair SPEC-02. It comes...
One of my favorite cases is the NZXT S340. It isn't too big, yet can fit an ATX motherboard with dual card configurations, and already comes with two pre-installed fans that move a decent amount of air and are quiet as well. I'll admit, it isn't ideal for a dual GPU setup (Crossfire particularly 😀.) but it'll get the job done with some decent temps while looking good too. For a single GPU system, even with a higher powered card, it'll be one of the best you can get. If you want a more open style case for better ventilation at the cost of quietness, then take a look at the Corsair SPEC-02. It comes with 2 front LED intake fans and is a case that is well worth it's price.
Here are some pictures of the cases that'll give you a good idea of the insides:
BitFenix Shinobi:
Corsair Carbide Series 200R:
Corsair SPEC-02:
And last but certainly not least, the NZXT S340:
