Try to connect a microphone to your computer and follow the steps below:
After you've plugged a microphone into a microphone jack on your computer and turned it on (if the microphone has an on button), follow these steps.
a. Open Sound by clicking the Start button, and then clicking Control Panel. In the search box, type sound, and then click Sound.
b. Click the Recording tab, click Microphone, and then click Properties.
c. Click the Levels tab and make sure the Mute button is not on. If the button looks like it enables, click it to turn on sound for this connection, and then click Apply.
d. (Optional) To listen to microphone sounds through your speakers or headphones, click the Listen tab, click the Listen to...
