Hello there,
This week my custom built PC has stopped sending signal to my monitor. It has been more than 2 years since I have been using it. My GPU is connected to my monitor but the monitor isn't displaying anything. The GPU's fan doesn't work but all the other fans including CPU's and the case fan work perfectly. Yes, I have checked my monitor and the PSU (by connecting the green and ground and measuring all the voltage drops) and they both work perfectly. There is one thing tho, when I connect the PSU to the motherboard It makes very noticeable and annoying noise like zzzzzzz. How do I know if my motherboard, GPU, PSU or CPU is faulty?
GPU: Gigabyte Nividia GT 430 Series
CPU: Intel Core i7 3820 3.6GHz Socket 2011 10MB
Maotherboard: Gigabyte GA-X79-UD3
Thanks!
Thanks!
