Looking for a full water system for my rig.
Bryant Caceres
81
Hey guys I'm looking for a full water system for my rig.
Here is my rig, http://pcpartpicker.com/p/2gyoV
Price really isn't to much of a problem, if anything I'll save up if I have too. I want the best system possible, I would also like it all to sit inside the case. Also I havent been able to find a full water block for my gpu. I'm aiming for at least 4.5 oc for the cpu, but if i can get more out of the system thatd be better
Well, keep in mind that even with a water cooling system you will have a very similar noise coming from the radiator on your rig.
Hi and welcome to Tom's Hardware forum.
I checked with EKWaterblocks for a full waterblock for that GPU and I can't find any one, ut you can go with a universal waterblock.
Now, my question is: Why do you want change the cooling systems of that GPU?
Well mostly I want cooler temps. Its running a little hot, and when i run my system at 90ish % it makes way to much noise. So I want to go with with custom water cooling. I'm thinking I might have to leave the gpu just running on air since I cant find a gpu block. But I would like to run my cpu on a custom water loop. Also if you can tell me what fans I can buy to upgrade my case fans, because at the moment they are wired into buttons that are at the front of the case to speed up or slow down the fans. But I can monitor the fan speeds, so I feel like it doesn't really help.
