Looking for a good graphics card for my pc-plz help
Natsu Mamoru
7
I am not good at knowing hardware things, plz help me choosing a good graphics driver that can play good decent new games, my budget is INR 3,000. my system system specs are:
System Information
Machine name: PAPA
Operating System: Windows 8.1 Pro 32-bit (6.3, Build 9600) (9600.winblue_gdr.140305-1710)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire Series
BIOS: Default System BIOS
Processor: Pentium(R) Dual-Core CPU E5400 @ 2.70GHz (2 CPUs), ~2.7GHz
Memory: 3072MB RAM
Available OS Memory: 3062MB RAM
Page File: 1821MB used, 1753MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 32bit Unicode
Your power supply is very low for any type of decent gaming card. Without a power supply upgrade you will not be able to play newer games. The lowest power low end gaming card is the R7 240 and that will be very close to the safe maximum of your system.
This card will fit in your case, even if it's a small case http://www.tomshardware.com/news/sapphire-r7-240-low-profile,26186.html but you are very close to power issues. You can get it, but you may be unstable without a better power supply.
Combined with your slower CPU, that video card is the minimum you'd want to run new games even on low settings.
The GT610 may be faster than your onboard video, and will run on lower power than the Radeon R7 240 but it is not close to a card...
Yea , You are good to go with a 450W or more PSU (Even 400W Would work)
With an Acer Aspire and the older CPU, you are OK with a low end gaming card. Post your exact model # and case style. I doubt your power supply is even a 300 watt one, and the case has to be large enough to hold certain cards. You may be limited to small form factor cards.
nVidia 750 ti may be the top card you can use, even that may not work depending on your power supply.
Model: Aspire Series E5400
and sorry but I don't know how to tell about a case style (I mentioned "I'm bad at hardware things" 🙁 ). plz tell me if I can run any software so that I can give all the required info.
Btw I am planning for "GeForce GT 610", will that be ok? plz answer,and thanks for the response.
The E5400 is just the CPU, not the computer model. Either way, I'm pretty sure you have a smaller case with a low watt power supply that will not work with any cards that are good for games. The GT 610 is not a good gaming card, but may be the only one that will fit your system. You will have to play games at low settings for anything newer, and some will play so bad you won't even want to play them.
If you get the full model # it may help more, the model should be on the case, and also on the documentation.
I don't know where to find what, I just opened the CPU and found the following: -
WO# : 31000208
ITEM# : AW.S23DS.287LE
ASP5400B/E5400/2GB/320
COMPONENT ITEMS DESCRIPTION
5W.05327.683 SATA HDD DATA CABLE
5W.37474.904 HEAT SINK LGA775TMFTM-175
BL.R0708.001 INTEL PROCESSOR SYSTEM LABE
HS.S133OD.003 HOUSING KITH403C+AMI20+F
KC.54001.DEV E5400(2.7GHZ/2MB/800FSB)PD
KH.32001.015 320GB 7200RPM SEAGATE 3.5"
KN.1GB07.005 1GB DDRII 800 UNB-DIMMKIN
KU.0160D.049 ODDHLDS SUPER-MULTI DRIV
MB.SA509.021 EG31M.INTELGBI+ICH7/RTL8
PY.2500B.04 PSULITE-ON PS-5251-7A-Ro
there was an orange slot(pretty wider) with number: P/N : MB.SA509.021 S/N A165863
and on another place the following was wriiten:
+3.3V & +5V TOTAL OUTPUT NOT EXCEED 110W
AT AMBIENT 25'C : TOTAL OUTPUT SHALL NOT EXCEED 250W
AT AMBIENT 50'C : TOTAL OUTPUT SHALL NOT EXCEED 212W
The GT610 may be faster than your onboard video, and will run on lower power than the Radeon R7 240 but it is not close to a card you'd want to use for games. The 610 is ranked about 400 in the video card chart, for a lower end gaming card, even an older model, it should be about 200 or lower.
thanks a lot Sir for answering all my queries and tolerating my lack of knowledge of hardware 😛 seems like I would change my system itself. thank you once again and all the members as well who answered the query.
