Archived from groups: microsoft.public.win98.gen_discussion (
More info?)
First pick one of these to identify what loads at boot. Next, see
whether there is an option in it's menus to disable it from starting up.
If you really want to rid yourself of it on a more permanent basis, then
look for it in "Control Panel, Add/Remove Programs". However, it isn't
often easy to know what is what in there. One of these URL's may say.
Only last, go to StartUpCop.
http://support.microsoft.com/default.aspx?scid=KB;EN-US;q137367
Startup Items
http://support.microsoft.com/kb/q179365/ Startup Group
http://aumha.org/a/loads.htm
http://web.ukonline.co.uk/sheppard.p/startup.htm
http://www.answersthatwork.com/Tasklist_pages/tasklist_a.htm
http://www.djbdesigns.com/wtvzone/startup.html
http://www.mlin.net/StartupCPL.shtml
http://www.pacs-portal.co.uk/startup_content.php
http://www.rickrogers.org/clean.htm
http://www.sysinfo.org/startupinfo.html
http://www.windowsstartup.com/wso/search.php
http://www2.cajun.net/~theriots/blk/start.htm
http://www2.whidbey.com/djdenham/Uncheck.htm
http://www.3feetunder.com/krick/startup/list.html
http://www.pcmag.com/ 's StartUpCop has "undo", and it is more than a
combination of "START, Run, MSInfo32, Software Environment, Startup
Programs" and "START, Run, MSConfig, Startup tab". It can even do a
permanent delete. Of course, first see whether the app has an option in
it's own menus to remove itself from the Startup Group. This is
configurable, and one may maintain multiple configurations.
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
"Warren" <nospam@nospam.com> wrote in message
news:u79kI7LkFHA.3608@TK2MSFTNGP12.phx.gbl...
| Can anyone recommend a good resource to help me identify processes
running
| on my computer? Most I understand but there's a few I don't and would
like
| to know why they are running.
| Thanks in advance.
