Looking for a Help
Ahmad_Hussain
Respected Members Hello!!!
OK. Recently one day i was playing Dota 2 Everything Was Fine then. Unfortunately my little bro pull out the 6 pin connectors of 3d card and then try to put it back , but i immediately turn off the Pc.. after that my card didnt show display, even its fan is not spining when i pluged it in my pci slot
after 2 days ( when this happen) my mob also stopped working , its like i start pc and it stuck on asus logo .My friends said change mobo , i changed it, The problem i am having now is that i use 4 different voltage and temp software ( one of them is asus ai suite 2) one of them is showing normal voltages one dnt show anything about mob and one show low volatges and the one which ASUS recommended gives proper voltages, I AM JUST ASKING PLZ TELL ME DO I NEED TO CHANGE MY PSU. ( i take my psu to an electronics expert and he used a high quality voltmeter and he said all voltages are normal each wire is showing either 3 5 12 or mention voltages on psu). plz help
Here are screen shots
http://imgur.com/a/XgBgi
XgBgi
Mate u didnt read it well. i said i change mobo after this happened , My new mobo is brand new i just inbox it 3 days ago.... I am just asking my bios and my asus software( which comes with board) shows normal cpu voltages and temp
but some other soft dnt which should i trust?
Latest posts
