Hello and thanks for checking out my thread.
I was wondering what the best performing cpu cooler setup would be for this pc. I don't want a gpu cooler yet
https://pcpartpicker.com/user/PizzaSlayer13/saved/
Most importantly I want it to keep my cpu very cool for overclocking, but I also want it to look cool. Double cool 😉
I need everything including tubing water block radiator pump etc.
I also would like it to have a 480mm radiator because I accidentally bought 8 static pressure fans anyway.
My case is the Azza Genesis 9000 so it will fit neatly anything.
Thanks!
Thanks!
