Looking for a low budget, thin and small laptop.
ElZak
Essentially I'll be using it for the Internet and using word or notepad. So these programmes run with no lag. Additionally Skype, however it doesn't need a built in mic. If you could help me out I'd appreciate it a lot. As long as it doesn't bob above £300 it's perfect! One final thing is that when on notepad/slimline(pretty much the same thing) it'd be great if the Fans are totally/near silent as I'll be using it a lot at don't want to distub others sitting next to me with the whirring of the fans. Thank you again!
For what you're looking for, you've got a pretty decent budget there.
Depends on how 'small' and 'thin' you want.
Some examples (if you can maybe identify one that you like the look/size etc of, you can likely get some more feedback).
14" Convertible ... i3
http://www.laptopsdirect.co.uk/Lenovo_A1_Flex_2-14_Intel_Core__i3-4010U_6GB_1TB_14_Touchscreen_Windows_8__A1-59433754/version.asp
11.6" Laptop - AMD
http://www.laptopsdirect.co.uk/Acer_V5-123_Silver_11.6_INCH_AMD_E1_2100_4GB_500GB_Shared_No_Opt_Win8.1_SST_NX.MFREK.006/version.asp
15.6" i3
http://www.laptopsdirect.co.uk/Toshiba_R50-B-12X_15.6IN_CI3-4005U_4GB_500GB_PSSG0E-024001EN/version.asp#top
Barty1884
Retired Moderator
11.6" Laptop - AMD
15.6" i3
