Looking for a Mid Tower Case. Need help
Crixus
Commendable
Oct 28, 2016
48
So i have all my parts for my computer but i need a case for them i have a medium size desk so i want a mid tower rather than a full tower case here are my parts
PS i want a case with some dust filters. My budget is $60
[PC specs]
CPU- i5 3570k
GPU- GTX 1050 ti
PSU- Corsair 650 non modular Bronze 80
MOBO- gigabyte ga z77 hd3
SSD- Samsung 250gb
HD- WD 1TB
If your willing to spend a little extra you can get the Corsair Carbide Series Spec-01 mid Tower for $69. Its includes a front dust filter and PSU dust filter and is very good for cable management as well has have a side window.
I would recommend getting a CPU Cooler if your gonna game especially if you are wanting to overclock the CPU. the case has good ventilation with fans but it wont be enough to save your CPU from overheating and frying your mobo.
I'd take the Fractal over the Corsair anyday. I'd just spend an extra few $ and get an extra fan or 2 and finish out the airflow, leaving both the stock fans as intakes. That'll mean Op can turn down the rpm on all the fans, since the pc is on the desktop, minimizing noise.
